Setting up the Fax Server Kit on Your Xerox System
FaxPress Enterprise and Xerox integration requires the Xerox system to be assigned a static IP address. Assign a static IP address to the Xerox system, then take the following steps to configure the Xerox system’s Fax Server Kit for operation with the FaxPress Enterprise:
| 1. | Open your Web browser on a workstation connected to the local network. |
| 2. | Type the Xerox system’s static IP address in the browser’s address field, http://192.128.128.14 in this example. When you press enter, a screen similar to the one below will appear. |
| 3. | Click on the Properties tab and expand the Properties tree. |
| 4. | Expand the Services folder, then the Fax folder. |
| 5. | Select the Fax Repository Setup. |
| 6. | In the Fax Repository Setup window, select SMB (the Windows share option) from the Protocol pulldown menu. |
Click the IP Address radio button, then specify the IP address of the workstation on which you set up the fax repository in Creating the Fax Repository Folder.
In the Share field, enter the Share name of the fax repository folder you created in Creating the Fax Repository Folder. XeroxDrop1 is used in the example above.
Leave the Document Path field blank.
Enter the Login Name and Password of a user account on the workstation or server where the repository folder is located (typically, the FaxPress Xerox Interface workstation). Castelle recommends that you use the workstation’s local administrator account.
| 7. | Click Apply. |
| 8. | The Enter Network Password window will display the User Name and Password of the account required for the Xerox system. By default, the User Name is admin and the password is 1111. Leave these fields at their default settings and click OK. |
After you have created and configured the fax repository, and configured the FaxPress Enterprise Xerox Interface (see Configuring the FaxPress Enterprise Xerox Interface), faxes sent from the configured Xerox system will automatically be routed to the fax repository folder. Each time you send a fax from the Xerox system, a ****.XSM folder will appear in the repository folder. The **** will be a number starting with 0001.XSM and will increment as more faxes are sent.
Last Updated: 11/1/2007
E-mail this page |
